Altera_ForumHonored Contributor12 years agowhat should i replace with question mark? hi every body this is my code architecture structure of main is ..... begin L1:for s in 0 to N-1 generate L2:for t in 0 to 2**s-1 generate ...Show More
Recent DiscussionsTiming analysis - long combinational pathQuartusPro 25.3 Crashed after using the Signal Tap Logic AnalyzerDuplicate_hierarchy_depth / duplicate_registerAutomatically added negative node for TDS output doesn't work with Agilex 5Quartus 20.1std compilation fails for Quartus map - Device 10AS057K2F40I1SG
