RayHaynes1
2 years agoWhat is this file - dcalc_extrapolate_dump_0000.txt
With each build a file called dcalc_extrapolate_dump_0000.txt (0000 increments each time) is generated. It's over 1/2 gigabyte in size. It start being created during the Early Timing Analysis and fin...
- 2 years ago
Noticed in the GUI message window at the start of a build a message stating that the ipgenerate tool was using an INI file (quartus.ini). Curious what might be in it I took a look and low and behold found this line. So it's apparently some debug feature of Quartus. No idea why it was set on mine
dcalc_force_negative_transitions_to_zero_and_print_debug_warning=onSet it to off and those files are no longer created. Problem solved :-).
sstrell
2 years agoWhere is this file appearing? Never seen this.
Is your design running any code that could generate this? Doesn't look like a standard file output by Quartus.
