11 years agoFor simple projects, you're only responsible for pin location assignments.
There is an automatically generated .tcl file which applies those constraints for you. You need to run that script (once). http://www.altera.com/literature/hb/external-memory/emi.pdf Review "Table 2-1: Design Checklist" and then search for "pin_assignments.tcl" elsewhere in the document for additional instructions. Manually looking for and changing those assignments within the GUI is done in the "Assignment Editor", not "Pin Planner".
