13 years ago --- Quote Start --- If your design passes timing with cell delay plus IC delay then you passed. Then you don't really need to worry about the case when 0 IC delay is applied because it is unrealistic and is meant as early diagnostic measure. --- Quote End --- --- Quote Start --- Timing closure is the name of what "TimeQuest and fitter and optionally synthesis stage" have to do to achieve best results for timing which may be pass or fail. --- Quote End --- Thanks very much, Kaz
