12 years agothe code I posted is what I was using for the multiplier verbatim (copied and pasted from the .vhd file). It is attached to other things but I bypassed them to just have it display on the 7segmented display. I know the display works fine because if I wire it up to the button press or use an input signal from a function generator it produces the correct values.
