12 years ago --- Quote Start --- For example if the constant is 13, the display reads the following solutions for each multiplication: 0x13=0; 1x13=13; 2x13=54; 3x13=39; 4x13=76; 5x13=65; etc... As you can see, some of the values are correct, however others are plain wrong. --- Quote End --- The symptom nevertheless is that (so far we can see) the results for even inputs are incorrect. Not that the button is bouncy. I repeat that we very probably don't see the real code from dropneedle. That what he has shown is basically correct, and supporting Frank, the problem must lie elsewhere in his code.
