9 years agoWeird SignalTap behaviour
Trying to solve a mystery, but after several days ran out of thoughts :(
Needed to connect to SignalTap around 100 (probably, a bit less) signals, and at some moment got very strange picture (attached): First (upper) signal – directly from PLL, 14.318 MHz frequency Second signal – inversion of first signal SignalTap clock – second output of the same PLL, 210MHz The behavior of the circuit tells me that the signals are absolutely fine (nothing would work if the picture is true). After removing most of signals to SignalTap (basically, keeping only the mentioned two signals), suddenly everything is OK – no more strange glitches on the picture. FPGA – Cyclone IV, using DE2-115 board Any thoughts would be greatly appreciated ! :)
