9 years agoWeird SignalTap behaviour
Trying to solve a mystery, but after several days ran out of thoughts :( Needed to connect to SignalTap around 100 (probably, a bit less) signals, and at some moment got very strange picture (...
9 years agoI tried the reread operation - did not help.
I'm doubtful JTAG transmission is an unlikely culprit as this only occurs on some builds and when it does happen it fails repeatedly. I have noticed that it fails when I push the capture clock frequency. I still don't suspect metastability because the source signal is stable. However, when I relax the clock with a lower frequency the problem goes away.
