Ways to improve timing on Top module?
What is your interconnect usage? Designs with an average value below 50% typically do not have any problems with routing. Designs with an average between 50-65% may have difficulty routing. Designs with an average over 65% typically have difficulty meeting timing unless the RTL tolerates a highly utilized chip. Peak values at or above 90% are likely to have problems with timing closure; a 100% peak value indicates that all routing in an area of the device has been used, so there is a high possibility of degradation in timing performance.
KhaiY
Average interconnect usage (total/H/V) 50.7% / 48.7% / 57.0%
Peak interconnect usage (total/H/V) 80.4% / 81.7% / 86.1%
Since average interconnect is less it should not cause any problems in routing right ?
But 8 out of 10 times fitter terminates because of routing congestion.
Is there a way to find which module has high interconnect usage ? So that I can change the coding style and improve timing .
- KhaiChein_Y_Intel6 years ago
Hi Yogesh,
Yes. There is a way to check which module uses most of the routing resources.
KhaiY
- Yogesh6 years ago
Hi Khai,
I think the screenshot you shared is for quartus pro edition. I am using intel quartus standard edition 18.1
I find only routing usage summary under logic and routing section ,which only talks about resources like Block interconnects
C12 interconnects
C2 interconnects
C4 interconnectsand not about module level usage . Is there someother option to check the same w.r.t each module of my project?
thankyou
regards,
Yogesh
Hi Yogesh,
The report in the Pro edition is different from the Standard edition. In this case, you have to check the routing utilization in the Chip Planner.
KhaiY
