12 years ago
way to use NOT() or ! operator in ADHL to switch between VCC and GND?
I inherited a AHDL code in Quartus II, that I have been able to modify, but I'm not proficient. Is there anyway to negate a variable that is set to either VCC or GND? I've seen that ! works in VHDL, but it doesn't appear to work in AHDL. And neither does NOT(). I'm basically looking for a way to switch between two states on every run. Hopefully the example (and purely illustrative) code makes this clearer.
skip = VCC;
ccd_state = state1;
some kind of loop
IF (skip == VCC) THEN
ccd_state = state1;
skip = !skip;
ELSIF (some other condition) THEN
ccd_state = state2;
skip = !skip;
ELSE
Something else
Elliot
    ! is not an operator in VHDL.
    ! is the not operator in AHDL.
    Where are you trying to compile this code?
    I'm not sure what you mean about where I'm compiling the code. I'm doing everything in Quartus II. Like I said, I'm far from proficient in this.
    It was just that you got your languages mixed up in your origional post and wondered if you tried to compile AHDL in modelsim or something.
    You never actually said what the problem was other than "it doesnt work". Are there any error messages? is it just not working on hardware like you expected?
