--- Quote Start ---
I'm having similar warnings. My hex file is being generated by NIOS ii SBT for eclipse. From this link (
https://www.altera.com/support/support-resources/knowledge-base/solutions/rd03252015_881.html) altera shows the solution.
"Description
You may see this warning when using memory initialization files generated by the mem_init make target in the makefile generated by the Nios® II Embedded Design Suite (EDS).
The reason for this warning is that the Quartus® II software expects the record length within .hex files to match the data port width of the memory that is initialized.
Workaround/Fix
To change the generated .hex files to have a record length that matches the memory data port width, modify the mem_init.mk file within the BSP directory:
Find the ELF_TO_HEX_CMD_NO_BOOTLOADER command
add the following switch:
--record=/8
This problem is scheduled to be resolved in a future release of the Quartus II software."
Based on the solution above, I'm not sure where to add the switch that was mentioned above.
The boot loader command I found on my mem_init.mk file is below
"ELF_TO_HEX_CMD_NO_BOOTLOADER = $(ELF2HEX) $< $(mem_start_address) $(mem_end_address) --width=$(mem_hex_width)
$(mem_endianness) --create-lanes=$(mem_create_lanes) $(elf2hex_extra_args) $@"
Question is where to add the --record=/8?
--- Quote End ---
Hello I am facing the same problem. The question is where to add it;
As you can see in the following, I have appended it but still the same warning
--record=/8 $(mem_endianness) --create-lanes=$(mem_create_lanes) $(elf2hex_extra_args) $@
Need help.
Thank you all.
