17 years agowarning with on chip memory data items width
hello, I use quartus II 8.0 and statixII gx ep2s60GX. I made a modification in my current design (which works well) in .vhd file. Now I've got this warning from onchip memory. ...
9 years agoELF_TO_HEX_CMD_NO_BOOTLOADER = $(ELF2HEX) --record=4 $< $(mem_start_address) $(mem_end_address) --width=$(mem_hex_width)
$(mem_endianness) --create-lanes=$(mem_create_lanes) $(elf2hex_extra_args) $@ I get the idea from the reply of @erics96 "In the elf2hex converter, there is an option called "--record=<length>" where you can set the maximum number of words per line... Changing my makefiles to use --record=4 created a .hex file that had only 4 bytes per line and produced no warnings."
