Warning Msg in system console "could not resgister IService packet"
- 3 years ago
Those warnings probably are not the root cause. I encountered same warnings as well but don't have problem at performing system console check image below.
I follow the tcl script (main.tcl) attached below for your reference in this example design https://www.intel.com/content/www/us/en/docs/programmable/683758/21-3-19-2-0/hardware-test-for-system-console-control.html
Make sure you have correct $master_index. May be can try to run simple commands below to check whether the problem still exist:
set master_path [ lindex [ get_service_paths master ] $master_index ]
open_service master $master_path
master_write_32 $master_path
Sheng
Glad to hear that the system console problem had been resolved. As for HW_TEST : FAIL problem, probably have to open a new thread in this forum https://community.intel.com/t5/FPGA-SoC-And-CPLD-Boards-And/bd-p/fpga-soc-cpld-boards-kits targeted on related ip hardware configuration.
Sheng
Thank you for your help.
I'll ask hw issue solution to HW community.
Have a good day!
