Warning Msg in system console "could not resgister IService packet"
- 3 years ago
Those warnings probably are not the root cause. I encountered same warnings as well but don't have problem at performing system console check image below.
I follow the tcl script (main.tcl) attached below for your reference in this example design https://www.intel.com/content/www/us/en/docs/programmable/683758/21-3-19-2-0/hardware-test-for-system-console-control.html
Make sure you have correct $master_index. May be can try to run simple commands below to check whether the problem still exist:
set master_path [ lindex [ get_service_paths master ] $master_index ]
open_service master $master_path
master_write_32 $master_path
Sheng
Sheng
Thank you for your help,
I have done HW_Test as you mentioned but.... result was failed...
So, what could be causing the HW issue? could you let me know how can I fix this error?
or do you need more information about HW?
Again, thank you so much for your help.
Below is the log in Tcl console.
% get_service_paths master
{/devices/5SGXEA7H(1|2|2ES|3|3ES)|..@1#USB-0/(link)/JTAG/(110:132 v1 #0)/phy_0/master}
{/devices/5SGXEA7H(1|2|2ES|3|3ES)|..@1#USB-0/(link)/JTAG/(70:34 v3 #0)/nios2_0}
% source main.tcl
Info : {/devices/5SGXEA7H(1|2|2ES|3|3ES)|..@1#USB-0/(link)/JTAG/(110:132 v1 #0)/phy_0/master} {/devices/5SGXEA7H(1|2|2ES|3|3ES)|..@1#USB-0/(link)/JTAG/(70:34 v3 #0)/nios2_0}
master_list_length = 2
--- Initialization (Check master path) ---
Info : Master path=/devices/5SGXEA7H(1|2|2ES|3|3ES)|..@1#USB-0/(link)/JTAG/(70:34 v3 #0)/nios2_0 and Index= 1
% start_basic_test
---Read Initial Status----
PIO Status = 0x10c00326
Reset done!
Enabled loopback done
Waiting for reset seq active low...
Reset seq active low
Link and frame reset held
Setting tx_test & rx_test registers...
Set test mode to PRBS test pattern
Link and frame reset released
Error status registers cleared
TX Error Status= 0x000000ff
RX Error0 Status= 0x000000ff
RX Error1 Status= 0x000003ff
Pulse sysref done!
tx_status: 0x000000ff
rx_status1: 0x000000ff
rx_status2: 0x000003ff
rx_status1_masked = 0x1
f_value: 3
k_value: 1
rbd_count: 254
offset = 252
Reset done!
New RBD offset = 254
Pulse sysref done!
Status: 0x26 (Masked value)
Info: Bit 0 - Core PLL Locked
Info: Bit 1 - TX XCVR Ready
Info: Bit 2 - RX XCVR Ready
Info: Bit 3 - Patchk Data Error
Info: Bit 4 - Tx Link Error
Info: Bit 5 - Rx Link Error
TX Status0: 0x4 (Masked value)
Info: Bit 0 - SYNC_N
Info: Bit {2:1} - Data Link Layer (DLL)
- 00: Code Group Synchronization (CGS)
- 01: Initial Lane Alignment Sequence (ILAS)
- 10: User Data Mode
- 11: D21.5 test mode
RX Status0: 0x0 (Masked value)
HW_TEST : FAIL
Read Error Status Register
TX Error Status = 0x000000ff
RX Error0 Status = 0x000000ff
RX Error1 Status = 0x000003ff
