18 years agoThe tri-state and enabel look correct. But there doesn't appear to be a feedback path on the bidir pin(i.e. when the tri-state is in the high-Z state, how does external logic drive back into the device?)
Also, looking at what you sent, why does sram_data feed another tri-state? Does it go off chip? You only need one tri-state per bidir, not two.
