12 years agoThank you so much FvM. Yes, you are right.
The warnings disappeared and it replaced by new errors that do not make sense to me. I connected the same wire to several blocks and I got these errors. It shows only for these two blocks that mentioned below. I did the same for others, but it does not show as an error. I attached the new project and thank you again for your time. Error (12014): Net "tr_w1[11]", which fans out to "FU_reg:TR_reg_Inst|in0[11]", cannot be assigned more than one value Error (12015): Net is fed by "amz_mul_1:amz_mul_1_inst|result[23]" Error (12015): Net is fed by "amz_div_1:amz_div_1_inst|remain[11]" Error (12014): Net "tr_w1[10]", which fans out to "FU_reg:TR_reg_Inst|in0[10]", cannot be assigned more than one value Error (12015): Net is fed by "amz_mul_1:amz_mul_1_inst|result[22]" Error (12015): Net is fed by "amz_div_1:amz_div_1_inst|remain[10]" Error (12014): Net "tr_w1[9]", which fans out to "FU_reg:TR_reg_Inst|in0[9]", cannot be assigned more than one value Error (12015): Net is fed by "amz_mul_1:amz_mul_1_inst|result[21]" Error (12015): Net is fed by "amz_div_1:amz_div_1_inst|remain[9]" Error (12014): Net "tr_w1[8]", which fans out to "FU_reg:TR_reg_Inst|in0[8]", cannot be assigned more than one value Error (12015): Net is fed by "amz_mul_1:amz_mul_1_inst|result[20]" Error (12015): Net is fed by "amz_div_1:amz_div_1_inst|remain[8]" Error (12014): Net "tr_w1[7]", which fans out to "FU_reg:TR_reg_Inst|in0[7]", cannot be assigned more than one value Error (12015): Net is fed by "amz_mul_1:amz_mul_1_inst|result[19]" Error (12015): Net is fed by "amz_div_1:amz_div_1_inst|remain[7]" Error (12014): Net "tr_w1[6]", which fans out to "FU_reg:TR_reg_Inst|in0[6]", cannot be assigned more than one value Error (12015): Net is fed by "amz_mul_1:amz_mul_1_inst|result[18]" Error (12015): Net is fed by "amz_div_1:amz_div_1_inst|remain[6]" Error (12014): Net "tr_w1[5]", which fans out to "FU_reg:TR_reg_Inst|in0[5]", cannot be assigned more than one value Error (12015): Net is fed by "amz_mul_1:amz_mul_1_inst|result[17]" Error (12015): Net is fed by "amz_div_1:amz_div_1_inst|remain[5]" Error (12014): Net "tr_w1[4]", which fans out to "FU_reg:TR_reg_Inst|in0[4]", cannot be assigned more than one value Error (12015): Net is fed by "amz_mul_1:amz_mul_1_inst|result[16]" Error (12015): Net is fed by "amz_div_1:amz_div_1_inst|remain[4]" Error (12014): Net "tr_w1[3]", which fans out to "FU_reg:TR_reg_Inst|in0[3]", cannot be assigned more than one value Error (12015): Net is fed by "amz_mul_1:amz_mul_1_inst|result[15]" Error (12015): Net is fed by "amz_div_1:amz_div_1_inst|remain[3]" Error (12014): Net "tr_w1[2]", which fans out to "FU_reg:TR_reg_Inst|in0[2]", cannot be assigned more than one value Error (12015): Net is fed by "amz_mul_1:amz_mul_1_inst|result[14]" Error (12015): Net is fed by "amz_div_1:amz_div_1_inst|remain[2]" Error (12014): Net "tr_w1[1]", which fans out to "FU_reg:TR_reg_Inst|in0[1]", cannot be assigned more than one value Error (12015): Net is fed by "amz_mul_1:amz_mul_1_inst|result[13]" Error (12015): Net is fed by "amz_div_1:amz_div_1_inst|remain[1]" Error (12014): Net "tr_w1[0]", which fans out to "FU_reg:TR_reg_Inst|in0[0]", cannot be assigned more than one value Error (12015): Net is fed by "amz_mul_1:amz_mul_1_inst|result[12]" Error (12015): Net is fed by "amz_div_1:amz_div_1_inst|remain[0]" Error (12014): Net "overflow_sig", which fans out to "FU_reg:TSR_reg_Inst|in0[9]", cannot be assigned more than one value Error (12015): Net is fed by "amz_add_sub_1:amz_add_sub_1_inst|overflow" Error (12015): Net is fed by "amz_log_shift:amz_log_shift_inst|overflow" Error (12015): Net is fed by "amz_arith_shift:amz_arith_shift_inst|overflow" Error: Quartus II 64-Bit Analysis & Synthesis was unsuccessful. 40 errors, 1 warning Error: Peak virtual memory: 435 megabytes Error: Processing ended: Thu Feb 27 10:34:49 2014 Error: Elapsed time: 00:00:02 Error: Total CPU time (on all processors): 00:00:02
