VWF Simulations in Quartus Prime Lite 23.1
Halo, I have a question.
I am running a VWF simulation using Quartus prime, but I am getting an error.
I have tried registering the license, setting the path, etc., but it does not go away.
erraor message,
Error: Invalid license environment. Application closing.
Unable to checkout a license. Make sure your license file environment variable (SALT_LICENSE_SERVER, MGLS_LICENSE_FILE, LM_LICENSE_FILE)
is set correctly and then run 'lmutil lmdiag' to diagnose the problem.
Unable to checkout a license. Vsim is closing.
Please let me know the cause.
Greetings from Japan,
taiga
- RichardT_altera
The error indicate that the license is not found. If you are using Questa intel FPGA starter edition as your EDA tool, in Assignment > Setting > EDA Tool Setting, check that your license file has "intelqsimstarter". intelqsim for non-starter edition.
Could you try to open the simulator tool standalone? If no, something might have goes wrong with the license file or license setup.
Richard Tan
- taiga716
I checked and could not find a license file named "intelqsimstarter".
I am using Questa intel FPGA starter edition,
Is there any other way to deal with this?- RichardT_altera
Checkout this User Guide (UG) on how to obtain the license:
https://www.intel.com/content/www/us/en/docs/programmable/683472/24-1/and-software-license.html
Richard Tan
- RichardT_altera
Do you able to resolve the issue?
Regards,Richard Tan
- RichardT_altera
If you have any further questions or concerns, please don't hesitate to let us know.
Richard Tan
