18 years agoYou should be able to directly write to array. What happens to your array when Quartus later synthesizes(?) the code is that it will save the data in a register or in a memory. In the mega wizard you can auto generate vhdl-blocks that will be placed in a memory block on the fpga.
I'm not sure I'm making any sense now, a bit tired. I'll have a quick look at your code instead. //Ola
