18 years ago --- Quote Start --- I would recommend using TimeQuest, in which case you need to put a clock constraint on the input clock and a derive_pll_clocks command. --- Quote End --- Or "derive_pll_clocks -create_base_clocks", which will make TimeQuest use the PLL megafunction settings to automatically produce the create_clock on the base clock feeding the PLL as well as the generated clocks driven by the PLL.
