11 years agoThank you for the suggestions.
Given that the video side is read only, and the NIOS is write only, the registers make a lot of sense (I had my head stuck with the idea of dual-port RAM). Also, the registers are likely to be much lower resource overhead than the associated DP RAM. A dual port 192 x 1 packed array is scary, plenty of oppertunities to misplace a bit or two. Regards, Mark
