16 years agoYou should post a minimal complete example code, that allows to reproduce the problem. I'm using a lot of similar constructs and they are generally understood by Quartus as expected. There may be a problem caused by the 0 TO 6 range, you can try if the result changes when you restrict the assignment to valid codings of int_time.
