16 years agoI found a solution. It works when I make the following change to the procedure:
procedure dl_rx_gen ( signal clk : in std_logic; signal encoded_symbol : in std_logic_vector(13 downto 0); signal dl_serial_out : out std_logic ) is begin wait for 1 ps; -- loop for each half bit of encoded symbol for i in encoded_symbol'range loop dl_serial_out <= encoded_symbol(i); wait for dl_bit_period/2; -- two values per bit period for manchester encoding end loop; end procedure; It seems that the simulator did not like the fact that the encoded_symbol value was getting set and that value was being used to set dl_serial_out all in the same instant in time.
