11 years agoVHDL Slot Machine
I am trying to make a program on a DE-1 board. It is a slot machine. The board will use 3 buttons. One for manual stopping numbers, one for automatically stopping all the numbers, and one to reset. The autostop portion will use a random number generator. I have no idea what is going wrong with this and I know there is a lot. Can somebody help? I attached my entire vhd file. It is also right here:
Library ieee; use ieee.std_logic_1164.ALL; use ieee.std_logic_arith.ALL; use ieee.math_real.ALL; entity project is port ( manualStop, autoStop, reset, clock : in std_logic; ssd3, ssd2, ssd1, ssd0 : out std_logic_vector(0 to 6)); end project; architecture arch of project is type display is array(0 to 9) of std_logic_vector(0 to 6); constant displayMap: display := ("0000001", "1001111", "0010010", "0000110", "1001100", "0100100", "0100000", "0001111", "0000000", "0000100"); type display2 is array(0 to 3) of std_logic_vector(0 to 6); constant winDisplay: display2 := ("0000110", "1001111", "0001001", "0001000"); constant loseDisplay: display2 := ("1110001", "0000001", "0100100", "0110000"); signal slowClock : std_logic := '0'; begin process(clock) variable counter : integer := 0; begin if rising_edge(clock) then if (counter = 200000) then --24Mhz/60hz/2 slowClock <= not slowClock; counter := 0; else counter := counter + 1; end if; end if; end process; process(slowClock) variable spin1 : integer := 1; variable spin2 : integer := 1; variable spin3 : integer := 1; variable spin4 : integer := 1; variable fini**** : integer := 0; variable value1 : integer := 0; variable value2 : integer := 2; variable value3 : integer := 3; variable value4 : integer := 6; variable rand: real; variable s1 : positive := 1; variable s2 : positive := 1; variable waiter: integer := 1; begin if (rising_edge(slowClock)) then loop if( spin1 = 1 ) then value1 := ((value1 + 1) mod 9); end if; if( spin2 = 1 ) then value2 := (value2 + 1) mod 9; end if; if( spin3 = 1 ) then value3 := (value3 + 1) mod 9; end if; if( spin4 = 1 ) then value4 := (value4 + 1) mod 9; end if; wait for 300 ms; ssd3 <= displayMap(value4); ssd2 <= displayMap(value3); ssd1 <= displayMap(value2); ssd0 <= displayMap(value1); if (fini**** = 1) then UNIFORM(s1, s2, rand); waiter := INTEGER(TRUNC(rand*10.0)); for I in 1 to waiter loop if( spin1 = 1 ) then value1 := (value1 + 1) mod 9; end if; if( spin2 = 1) then value2 := (value2 + 1) mod 9; end if; if( spin3 = 1 ) then value3 := (value3 + 1) mod 9; end if; if( spin4 = 1 ) then value4 := (value4 + 1) mod 9; end if; wait for 300 ms; ssd3 <= displayMap(value4); ssd2 <= displayMap(value3); ssd1 <= displayMap(value2); ssd0 <= displayMap(value1); end loop; if ( spin1 = 1 ) then spin1 := 0; elsif ( spin2 = 1 ) then spin2 := 0; elsif ( spin3 = 1 ) then spin3 := 0; elsif ( spin4 = 1 ) then spin4 := 0; end if; elsif ( manualStop = '0' ) then if ( spin1 = 1 ) then spin1 := 0; elsif ( spin2 = 1 ) then spin2 := 0; elsif ( spin3 = 1 ) then spin3 := 0; elsif ( spin4 = 1 ) then spin4 := 0; end if; elsif ( autoStop = '0' ) then fini**** := 1; elsif ( reset = '0' ) then spin1 := 1; spin2 := 1; spin3 := 1; spin4 := 1; fini**** := 0; value1 := 0; value2 := 2; value3 := 3; value4 := 6; end if; if ( spin1 = 0 ) and ( spin2 = 0 ) and ( spin3 = 0 ) and ( spin4 = 0 ) then if ( value1 = 0 ) and ( value2 = 0 ) and ( value3 = 0 ) and ( value4 = 0 ) then while ( reset = '1' ) loop wait for 1000 ms; ssd3 <= winDisplay(value4); ssd2 <= winDisplay(value3); ssd1 <= winDisplay(value2); ssd0 <= winDisplay(value1); wait for 1000 ms; ssd3 <= displayMap(value4); ssd2 <= displayMap(value3); ssd1 <= displayMap(value2); ssd0 <= displayMap(value1); end loop; else while ( reset = '1' ) loop wait for 1000 ms; ssd3 <= loseDisplay(value4); ssd2 <= loseDisplay(value3); ssd1 <= loseDisplay(value2); ssd0 <= loseDisplay(value1); wait for 1000 ms; ssd3 <= displayMap(value4); ssd2 <= displayMap(value3); ssd1 <= displayMap(value2); ssd0 <= displayMap(value1); end loop; end if; end if; end loop; end if; end process; end arch; please help
