17 years agoYes, for the same reason, having an incomplete sensitivity list might cause behavior to differ from what you see in simulation. Because of this, it is always a good idea to specify a properly defined sensitivity list. A combinational logic process should be made sensitive to every signal you have on the right side of an assignment inside the process. By making this change, you will avoid simulation-synthesis mismatches.
