VHDL Quartus Simulation, Libraries and Packages
I have:
- an entity that implements a circuit for parity check: it have as input an 8 bit std_logic_vector and an std_logic as output. It is located in the folder: C:\User\Desktop\Conversioni_di_Tipo\ParityChecker\ParityChecker.vhd
- a function that converts a char in an 8 bit standard_logic_vector, defined in a package, located in the folder: C:\Users\Desktop\Conversioni_di_Tipo\myLibrary_1\ema_conversion_pkg.vhd
- a testbench which have that entity as DUT but that also uses the conversion function in the package. It is located in the folder: C:\Users\Desktop\Conversioni_di_Tipo\ParityChecker\simulation\modelsim\ParityChecker_tb.vhd
The Quartus project is located in the folder: C:\Users\\Desktop\Conversioni_di_Tipo\ParityChecker
The file added to the project is the ParityChecker.vhd (it is obviously the top-level entity).
The simulator is ModelSim-Altera.
The testbench file ParityChecker_tb.vhd is set in Assegniment --> Setting --> Simulation --> TestBenches...
I start the Analysis & Elaboration that go correctly to the end.
Then, I start RTL simulation, ModelSim open but an it gives these errors because it doesn’t find the package.
# Reading pref.tcl
# do ParityChecker_run_msim_rtl_vhdl.do
# if {[file exists rtl_work]} {
# vdel -lib rtl_work -all
# vlib rtl_work
# vmap work rtl_work
# Model Technology ModelSim - Intel FPGA Edition vmap 2020.1 Lib Mapping Utility 2020.02 Feb 28 2020
# Copying C:/intelFPGA_lite/20.1/modelsim_ase/win32aloem/../modelsim.ini to modelsim.ini
# Modifying modelsim.ini
# vcom -93 -work work {C:/Users//Desktop/Conversioni_di_Tipo/ParityChecker/ParityChecker.vhd}
# Model Technology ModelSim - Intel FPGA Edition vcom 2020.1 Compiler 2020.02 Feb 28 2020
# Start time: 17:36:37 on Nov 18,2020
# vcom -reportprogress 300 -93 -work work C:/Users//Desktop/Conversioni_di_Tipo/ParityChecker/ParityChecker.vhd
# -- Loading package STANDARD
# -- Loading package TEXTIO
# -- Loading package std_logic_1164
# -- Compiling entity ParityChecker
# -- Compiling architecture Behavioral of ParityChecker
# End time: 17:36:38 on Nov 18,2020, Elapsed time: 0:00:01
# Errors: 0, Warnings: 0
# vcom -93 -work work {C:/Users/Desktop/Conversioni_di_Tipo/ParityChecker/simulation/modelsim/ParityChecker_TB.vhd}
# Start time: 17:36:40 on Nov 18,2020
# vcom -reportprogress 300 -93 -work work C:/Users/Desktop/Conversioni_di_Tipo/ParityChecker/simulation/modelsim/ParityChecker_TB.vhd
# -- Loading package NUMERIC_STD
# ** Error: C:/Users/Desktop/Conversioni_di_Tipo/ParityChecker/simulation/modelsim/ParityChecker_TB.vhd(5): (vcom-1598) Library "mylibrary_1" not found.
# ** Error: C:/Users/Desktop/Conversioni_di_Tipo/ParityChecker/simulation/modelsim/ParityChecker_TB.vhd(6): (vcom-1136) Unknown identifier "myLibrary_1".
# ** Note: C:/Users/Desktop/Conversioni_di_Tipo/ParityChecker/simulation/modelsim/ParityChecker_TB.vhd(8): VHDL Compiler exiting
# End time: 17:36:40 on Nov 18,2020, Elapsed time: 0:00:00
# Errors: 2, Warnings: 0
# ** Error: C:/intelFPGA_lite/20.1/modelsim_ase/win32aloem/vcom failed.
# Error in macro ./ParityChecker_run_msim_rtl_vhdl.do line 10
# C:/intelFPGA_lite/20.1/modelsim_ase/win32aloem/vcom failed.
# while executing
# "vcom -93 -work work {C:/Users/Desktop/Conversioni_di_Tipo/ParityChecker/simulation/modelsim/ParityChecker_TB.vhd}"
Could you help me to understand how the libraries have to be handle in a corret manner, especially when user file (needed in a simulation) are arbitrarly located in the PC?
Thank you.
Here you can see the file discussed above.
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
ENTITY ParityChecker IS
GENERIC (oddParity: STD_LOGIC := '1'); -- ='1' per rilevare la parità dISpari
PORT ( x : IN STD_LOGIC_VECTOR (7 DOWNTO 0);
y : OUT STD_LOGIC);
END ParityChecker;
ARCHITECTURE Behavioral OF ParityChecker IS
BEGIN
PROCESS (x) IS
VARIABLE y_var: STD_LOGIC;
begIN
y_var := NOT(oddParity);
for i IN x'RANGE LOOP
y_var := y_var XOR x(i);
END LOOP;
y <= y_var;
END PROCESS;
END Behavioral;
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
package ema_conversions_pkg is
function char_to_slv (signal charIN: character; constant bitwidth: natural) return std_logic_vector;
end package ema_conversions_pkg;
package body ema_conversions_pkg is
function char_to_slv (signal charIN: character; constant bitwidth: natural) return std_logic_vector is
begin
return std_logic_vector(to_unsigned(CHARACTER'POS(charIN), bitwidth));
end function char_to_slv;
end package body ema_conversions_pkg;
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
library myLibrary_1;
use myLibrary_1.ema_conversions_pkg.all;
entity ParityChecker_TB is
end ParityChecker_TB;
architecture Behavioral of ParityChecker_TB is
signal y_tb: std_logic;
signal x_tb: std_logic_vector(7 downto 0);
begin
x_tb <= char_to_slv(charIN,8);
DUT: entity work.ParityChecker
generic map('1') -- ='1' per rilevare la parità dispari, ='0' per rilevare la parità pari
port map(x_tb, y_tb);
STIM: process is
begin
charIN <= 'a';
wait for 20 ns;
charIN <= 'c';
wait for 20 ns;
charIN <= 'F';
wait;
end process;
end Behavioral;
1 Reply
- RichardT_altera
Sorry for idling for some time. May I know do you able to solve the issue by yourself?
Do you need further help on this?
