11 years agoVHDL Partially Initialize in 0 a vector array
Im trying to create an array of vectors like shown in the code below:
type ram256 is array (0 to 255) of std_logic_vector (11 downto 0); signal memoria: ram256; The problem is that, initially i only use about the first 25 vectors of the type. I need the other ones to be 0 but since they're 256 vectors in total, its too long to do it manually. Can anyone help me how to do it? I tried with for loop but when i use the test bench after, it seems like the memory its full of U's. Thank you very much in advance.
