8 years ago[VHDL] how to manage lib name depending on the design entry?
Hi All, I want to use the different library names for the same Le's say I have a VHDL file with the following lines: library mylib_1;use mylib_1.abc.all; But, when I'm go...
8 years agoIn Verilog, there is "`define" where the names/paths might be defined
In VHDL, there are generics. But as far as I understand, they canoot help in this case... The import package (like in SystemVerilog) is there something similar in VHDL? In VHDL, can I include different files (like `include in Verilog) depending on configuration?
