9 years agoVHDL help for using built in Comparators
Hi all, when I try to use Quartus built in integer comparators I am experiencing some problem. I am trying to sort 64 numbers stored in a 2 port RAM. When I input the addresses and get back 2 ...
9 years agoPlease can you clarify what you mean - maybe highlight the problem lines or make the code example smaller. Your question is not clear
