9 years agoVHDL help for using built in Comparators
Hi all, when I try to use Quartus built in integer comparators I am experiencing some problem. I am trying to sort 64 numbers stored in a 2 port RAM. When I input the addresses and get back 2 ...
9 years agoI don't quite understand what the issue is. Are you saying the result should be put into mem2 on the same clock cycle as the comparison instead of the next cycle? It would help to see your PROCESS commands and sensitivity list assuming this is all synchronous to a clock.
