Altera_ForumHonored Contributor13 years agoVHDL getting Array elements with std_logic_vector Hello, I'm having some trouble synthesizing my code, I'm running out of logic cells on my DE2 Altera board. I want to use the values from 4 std_logic_vectors(7 downto 0) to retrieve the e...Show More
Altera_ForumHonored Contributor13 years agoyes, that would be a problem. But why do you need registers. Could you use a RAM instead?
Recent DiscussionsConnection bit order between hierarchyFree Licence for Max+PlusIIMAX10 ADC - getting it to simulate in ModelsimFailed to run ip-setup-simulation:Compile option not saved (reversed to default)
