13 years agoA reasonable way is to implement CollisonReg in internal RAM, changing the code to fulfill the requirements for RAM inference. The most important restriction is that you can't access more than two memory locations at a time if you utilize the dual-port feature. This means that the basic program algorithm has to be redesigned.
