11 years agoVHDL FILE_OPEN does not return correct status in Quartus
I have a procedure in VHDL that reads a line from file and is supposed to assign signal values based on individual characters of the line. The problem i am facing is that my FILE_OPEN statement seems...
11 years agoAny alternate for this ? I am trying to simulate an instruction sequence that i have written in file. The contents of the file looks as follows:
20020005
2003000c
2067fff7 Is there any way i can read these values and assign them to signals, or changing the tool is the only option ? --- Quote Start --- The problem here is that Quartus does not support memory initialisation from a text file in VHDL. I raised an enhancement request for this about 8 years ago, because Xilinx XST always has allowed the use of textio to initialise a ram. Annoyingly, Quartus does support this in verilog. Just a NOTE: if it did support it - then you are doing it in the wrong way anway - it needs to be done via a function at initialisation time, not runtime in a process. If the initialisation is easily done via a function, then Quartus does support initialisation via a function (unless it involves textio) Otherwise your only option is to create a .mif file. --- Quote End ---
