14 years agoVHDL "EVENT" Problem
Hello, I'm a beginner for using Quartus II. I have an error in this VHDL code
-------------------------------------------------------------------------------------- library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity Test is port(clk : in std_logic; preset : in std_logic; flag : in std_logic; out : out std_logic_vector(15 downto 0); done : out std_logic ); end Test; architecture RTL of Test is signal d :std_logic_vector(15 downto 0); signal q :std_logic_vector(15 downto 0); signal I :std_logic_vector(15 downto 0) := "0111010101001101"; signal flag_sgl : std_logic ; signal done_sgl, VI, : std_logic; begin process(clk,flag) begin if(preset= '0') then flag_sgl <= '0'; done_sgl <= '0'; VI <= '1'; elsif (clk'event and clk='1') then VI <= '0'; if (flag_sgl = '1')then flag_sgl <= '0'; done <= not(done_sgl); done_sgl <= not(done_sgl); out <= q(15 downto 0); q <= d; end if; end if; if (flag'event ) then flag_sgl <= '1'; end if; end process ; ------------------------ d(0) <= I(0) when VI = '1' else q(1) ; d(1) <= I(1) when VI = '1' else q(2) ; d(2) <= I(2) when VI = '1' else q(0) xor q(3) ; d(3) <= I(3) when VI = '1' else q(4) ; d(4) <= I(4) when VI = '1' else q(5) ; d(5) <= I(5) when VI = '1' else q(6) ; d(6) <= I(6) when VI = '1' else q(0) xor q(7) ; d(7) <= I(7) when VI = '1' else q(8) ; d(8) <= I(8) when VI = '1' else q(9) ; d(9) <= I(9) when VI = '1' else q(0) xor q(10); d(10) <= I(10) when VI = '1' else q(11) ; d(11) <= I(11) when VI = '1' else q(0) xor q(12); d(12) <= I(12) when VI = '1' else q(13) ; d(13) <= I(13) when VI = '1' else q(14); d(14) <= I(14) when VI = '1' else q(0) xor q(15); d(15) <= I(15) when VI = '1' else q(0); end architecture RTL; ----------------------------------------------------------------------------------------- I got a problem in the "RED" color line. I would like "flag_sgl" change value to '1', everytime that input signal "flag" change its value. Are there any way for detecting "flag" changing without using 'EVENT? Thank you in advance ^^
