16 years agoI see.
In some VHDL book it seems that "when" implicitly creates a process that internally does "if" instead. This of course is exactly what I wanted to avoid (even though I suppose when all cases are covered the compiler can optimize out the FlipFlops that the process needs to hold the sequential states). so instead of
load(i) <= '1' when (conv_integer(address) = i) else '0';
I'd better write something like
load(i) <= not (conv_integer(address) xor i);
Would this avoid the problem from ground up ? -Michael
