15 years ago
VHDL: DE2 Lab4 part1
I'm trying to follow lab 4, but am having problems. I was just told that my TFF was garbage, and it was pretty poetic, I wish i could post it for comic-relief, but anyway, I'd like to ask what you guys think of my TFF
entity myTFF is
        port( T, Clk, Reset     : in std_logic;
                        Q                       : out std_logic
end myTFF;
architecture behavioral of myTFF is
        signal buf : std_logic;
begin
        process(T, Clk, Reset)
        begin
                if(reset = '1') then
                        buf <= '0';
                end if;
                if(Clk = '1') then
                        if(T = '1')then
                                buf <= (NOT buf);
                        end if;
                end if;
        end process;
        Q <= buf;
end behavioral;
would love some feedback
thanks
malik
    In this case, what can be the interest to use an unsigned ?
    I am ok that it will not change the systhesis result, but personnaly I use types according to what they do. I use std_logic_vector if it is not a number or if they is no particular operation on it, and I use signed and unsigned if the vector corresponds to a number and if I have to make arithmetic operation on it.
    my only reason for using unsigned( that i can remember right now ) is cause it was recommended to me. Oh, and there are certain conversion functions that aren't IEEE when using std_logic_vector, that are when using unsigned. Whatever works for now :)
    And thanks, I was thinking of using a T() signal but wasn't sure how I would go about implementing it. Thanks for showing me that it wasn't that complicated. Now, it seems that my HEX ROM is a little buggy. But maybe that should be in another topic, since i think i want to ask what people see is wrong with it, and what would i use to debug it.
    Actually, I guess I should ask here, since it's about Lab1 :)
    Here's my HEX ROM:
    entity HEX is
    	port( HEXcnt	: in unsigned(3 downto 0);
    			HEXOut	: out std_logic_vector(6 downto 0)
    end HEX;
    architecture behavioral of HEX is
    	signal HEXInt : integer;
    	type SegROM is array (0 to 9) of std_logic_vector(6 downto 0);
    	constant segStates : SegROM := (
    		0 => "1000000",
    		1 => "1111001",
    		2 => "0100100",
    		3 => "0110000",
    		4 => "0011001",
    		5 => "0010010",
    		6 => "0000010",
    		7 => "1111000",
    		8 => "0000000",
    		9 => "0010000",
    --		others => (others => '0'));
    		others => "1000000");
    begin
    	process(HEXcnt, HEXInt) begin
    		HEXInt <= to_integer(unsigned(HEXcnt));
    		HEXOut <= segStates(HEXInt);
    	end process;
    end behavioral;
    when using the top-level file that i'll post below, i go from 0-9 fine, but after that, I get a backward looking 9 and 4 more characters from the array list above, as if my counter is going to 16. it is 4-bit, but i only want it to go to 9 before resetting to 0 and moving and incrementing the 10s place Seg.
    entity part1 is
    	port( 	KEY	 		: in std_logic;
    			SW			: in std_logic_vector(1 downto 0);
    			HEX0, HEX1	: out std_logic_vector(6 downto 0)
    end part1;
    architecture behavioral of part1 is
    	--create digits to represent the decimal number
    	subtype digit is integer range 0 to 9;
    	signal h1	: digit;
    	--use to convert the digits to slv
    	signal hv1	: unsigned(3 downto 0);
    	signal Qout : unsigned(15 downto 0);
    	signal Nout : integer;
    begin
    	cnt16 : entity work.TFFcounter16bit port map(SW(1), KEY, SW(0), Qout);
    	seg0 : entity work.HEX port map(Qout(3 downto 0), HEX0);
    	seg1 : entity work.HEX port map(hv1, HEX1);
    	process(Nout, h1) begin
    		if((Nout > 9) AND (Nout < 99)) then
    			h1 <= h1 + 1;
    		end if;
    	end process;
    	Nout <= to_integer(unsigned(Qout));
    	hv1 <= to_unsigned(h1, hv1'length);
    end behavioral;
    silly me, I'm trying to get it to display as decimal. It's telling me to use hex. sucks really, I would have loved to make it work in decimal as well
