my only reason for using unsigned( that i can remember right now ) is cause it was recommended to me. Oh, and there are certain conversion functions that aren't IEEE when using std_logic_vector, that are when using unsigned. Whatever works for now :)
And thanks, I was thinking of using a T() signal but wasn't sure how I would go about implementing it. Thanks for showing me that it wasn't that complicated. Now, it seems that my HEX ROM is a little buggy. But maybe that should be in another topic, since i think i want to ask what people see is wrong with it, and what would i use to debug it.
Actually, I guess I should ask here, since it's about Lab1 :)
Here's my HEX ROM:
entity HEX is
port( HEXcnt : in unsigned(3 downto 0);
HEXOut : out std_logic_vector(6 downto 0)
end HEX;
architecture behavioral of HEX is
signal HEXInt : integer;
type SegROM is array (0 to 9) of std_logic_vector(6 downto 0);
constant segStates : SegROM := (
0 => "1000000",
1 => "1111001",
2 => "0100100",
3 => "0110000",
4 => "0011001",
5 => "0010010",
6 => "0000010",
7 => "1111000",
8 => "0000000",
9 => "0010000",
-- others => (others => '0'));
others => "1000000");
begin
process(HEXcnt, HEXInt) begin
HEXInt <= to_integer(unsigned(HEXcnt));
HEXOut <= segStates(HEXInt);
end process;
end behavioral;
when using the top-level file that i'll post below, i go from 0-9 fine, but after that, I get a backward looking 9 and 4 more characters from the array list above, as if my counter is going to 16. it is 4-bit, but i only want it to go to 9 before resetting to 0 and moving and incrementing the 10s place Seg.
entity part1 is
port( KEY : in std_logic;
SW : in std_logic_vector(1 downto 0);
HEX0, HEX1 : out std_logic_vector(6 downto 0)
end part1;
architecture behavioral of part1 is
--create digits to represent the decimal number
subtype digit is integer range 0 to 9;
signal h1 : digit;
--use to convert the digits to slv
signal hv1 : unsigned(3 downto 0);
signal Qout : unsigned(15 downto 0);
signal Nout : integer;
begin
cnt16 : entity work.TFFcounter16bit port map(SW(1), KEY, SW(0), Qout);
seg0 : entity work.HEX port map(Qout(3 downto 0), HEX0);
seg1 : entity work.HEX port map(hv1, HEX1);
process(Nout, h1) begin
if((Nout > 9) AND (Nout < 99)) then
h1 <= h1 + 1;
end if;
end process;
Nout <= to_integer(unsigned(Qout));
hv1 <= to_unsigned(h1, hv1'length);
end behavioral;
