13 years ago --- Quote Start --- Many thanks for the reply, i've alreday done it using power electronics as u said, i am just thinking if there is a way to implemnt VHDL codes to generate the algorithm for the control --- Quote End --- I will assume then the control logic could very small. However for the forum to help you will need to describe your algorithm fully and clearly and also add information about fpga interface to the charging circuit (inputs/outputs).
