wait for "time" is not a synthesizable statement. There is no kind of Hardware wich would support this.
I agree to the others here: If you need the 25 ns timing you can use a enable signal wich is derived from a clock which runs at 40 Mhz and enable the output for one clock cylce.
When I look at your code, I've got one questions to you and the community, which is a little bit off topic:
In the case statement you use large bit vectors in binary coding.
when 3186=> data_out <= ("1010101101101001110100000011011");
I would use internally a 32 bit vector and code the output vector in this way
signal data_internal : std_logic_vector(31 downto 0);
begin
process
begin
if CLK'EVENT and CLK = '1' then
case...
when 3186=> data_internal <= x"55B4E81B"
end case;
end process;
data_out <= data_internal(30 downto 0);
end arch..;
I think this version has a better "readabiltiy". What do you think? What do the others in here think about this?
Regards Christian
