10 years agoVHDL Code for RISC PROCESSOR
I am working on 64-Bit RISC Processor. But there is a problem while linking register file and memory map file with main program. Please help me to make a code for 64-Bit RISC Processor.
Thanks4 Replies
Whats the problem?
--- Quote Start --- Whats the problem? --- Quote End --- thanks for replying when i run my program there is always a problem of port map. Xilinx gives syntax error near port. There are 2 programs one for memory mapping and another for register file. when i am trying to link them with main program then there is a problem. - Altera_Forum
Im sorry - my telepathy isnt working today. I suggest you read the error report - fix the code it's pointing to and then make it work. Without the actual errors or the code there is no more I can do.
Also - this is an Altera forum. We can help with code questions but Xilinx specific problems you need to go to the Xilinx forum: https://forums.xilinx.com/ - Altera_Forum
--- Quote Start --- Im sorry - my telepathy isnt working today. I suggest you read the error report - fix the code it's pointing to and then make it work. Without the actual errors or the code there is no more I can do. Also - this is an Altera forum. We can help with code questions but Xilinx specific problems you need to go to the Xilinx forum: https://forums.xilinx.com/ --- Quote End --- Thanks for replying sir
