13 years agovhdl code for n*n matrix inversion
hello
I want to write a vhdl code for real or complex matrix inversion. i don't know how i can send arrays of my matrix to output ports. i need your helps for writting this code because i'm beginner. tnx this is my code but it have errors: library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; use work.newtype.all; entity inverse is port(input: in matrix_t; --clk: in std_logic; inversed_matrix: out matrix_t); end inverse; architecture arch of inverse is function change (matrix: matrix_t) return matrix_t is variable ret,test: matrix_t; --variable a,b,c: integer ; begin --for i in matrix'range(1) loop --for j in matrix'range(2) loop test(0,0)<= matrix(1,1) * matrix(0,0); test(0,1)<= matrix(0,1) * matrix(1,0); test(1,1)<=test(0,0)-test(0,1); ret (0,0):= (matrix (1,1))/test(1,1); ret (1,1):= (matrix (0,0))/test(1,1); ret (0,1):= -(matrix (0,1))/test(1,1); ret (1,0):= -(matrix (1,0))/test(1,1); --end loop; --end loop; return ret; end ; --end function; begin inversed_matrix <= change (input); end arch; help me plz
