15 years agoTry this idea:
if you want to select in0 when select = 0000 then it means: select-------in0-------out 0000---------0-------0 0000---------1-------1 hence for nand gate invert all select lines and output and you get: select--------in0--------nand out inverted 1111----------0---------0 1111----------1---------1 for in1 when select = 0001 invert the first 3 lines and so on
