you can avoid copying the component declaration alltogether, by doing direct instantiation:
library ieee;
use ieee.std_logic_1164.all;
entity PCIad is port(
areset_sig: in STD_LOGIC;
inclk0_sig: in STD_LOGIC;
c0_sig: out STD_LOGIC;
locked_sig: out STD_LOGIC
end PCIad;
architecture archPCIad of PCIad is
begin
ALT_PLL_inst : entity work.ALT_PLL --this is the direct bit
PORT MAP (
areset => areset_sig,
inclk0 => inclk0_sig,
c0 => c0_sig,
locked => locked_sig
end archPCIad;
Again, you can even avoid using the wizard by using the altera_mf library. It gives me more direct control, and less extra rubbish/wrappers cluttering up my working directory (though I know some people prefer setting stuff up via the wizard):
library altera_mf;
use altera_mf.altera_mf_components.all;
--this comes from the altera_mf library
ALT_PLL_inst : altpll
generic map (
OPERATION_MODE => "NORMAL",
PORT MAP (
c0 => c0_sig,
all of the generics can be found via help -> megafunctions/lpm.
