9 years agoVHDL aggregate error
Hello I had errors that said , "Error (10514): VHDL aggregate error at gate.vhd(47): can't determine type of aggregate -- found 0 possible types"
What does it means ? Thank you LIBRARY ieee; USE ieee.std_logic_unsigned.ALL; USE ieee.numeric_std.ALL; USE ieee.std_logic_1164.ALL; entity gate is port( clk : in std_logic; reset : in std_logic; gate_out : out std_logic ); end gate; architecture gate_a of gate is --signal reset : STD_LOGIC := '0'; -- disabled reset; TODO move this signal to port signal timer_haut : UNSIGNED(25 downto 0) := (others => '0'); signal timer_bas : UNSIGNED(25 downto 0) := (others => '0'); signal timer_tick : STD_LOGIC; begin process(clk) begin if rising_edge(clk) then if (reset = '1') then timer_haut <= (others => '0'); else timer_haut <= timer_haut + 1; end if; end if; end process; process(clk) begin if rising_edge(clk) then if (reset = '1') then timer_bas <= (others => '0'); else timer_bas <= timer_bas + 1; end if; end if; end process; timer_tick <= '1' when (timer_haut = to_unsigned(50 * 1000 * 1000), timer_us'length) else '0' when (timer_bas = to_unsigned(60 * 1000 * 1000), timer_us'length); end gate_a;2 Replies
you've put the , in the correct place:
(timer_bas = to_unsigned(60 * 1000 * 1000), timer_us'length) should be (timer_bas = to_unsigned(60 * 1000 * 1000, timer_us'length) ) - Altera_Forum
Thank you ! lol
