When using a conditional in an IF statement, the ?? is not required. From the Doulos website:
"""VHDL-2008 introduces a new operator, ??. It ’s called the
condition operator and it converts a STD_LOGIC expression to a BOOLEAN one: '1' and 'H' are considered TRUE and everything else FALSE. (It also converts BIT to BOOLEAN .) So you can now write this:
if ?? A and B then
or, even better ...
In certain circumstances, ?? is applied implicitly. The condition expression of an if statement is one of those. So you can indeed now write:
if A and B then
Technically, in my code that I initially listed, I left out the
THEN in the line:
if HRST then:
I had the THEN statement in my code, just didn't copy it.
This compiles fine in Aldec HDL where VHDL 2008 is checked
as the language version.
I am trying to find out if Quartus needs the ?? or can discern
that that the bit literal should be TRUE.
