13 years agoVHDL-2008 support for unconstrained arrays in records
Quartus II does not support unconstrained arrays in records, which would be useful to define a complex-valued data type for signed values, eg.,
-- A complex-valued signed number
type complex...
PTorr1
7 years agoIt does not seem to be supported on Quartus 18.1
It is supported on Modelsim: "ALTERA STARTER EDITION vsim 10.5b Simulator 2016.10 Oct 5 2016", which is the one distributed with Quartus 18.1
When trying to use the following record in a file:
type t_avst_tosink is record
data : std_logic_vector;
sop : std_logic;
eop : std_logic;
valid : std_logic;
end record t_avst_tosink;I get the following error in quartus:
Error (10482): VHDL error at example.vhd(80): object "data" is used but not declared File: /home/user/example.vhd Line: 80
Error (10411): VHDL Type Conversion error at example.vhd(80): can't determine type of object or expression near text or symbol "t_avst_tosink" File: /home/user/example.vhd Line: 80
