11 years ago
VGA using VHDL
Hi guys.
I have problem with my VHDL code. I want to use VGA monitor for my project. Here is the coding for my testing. But, this have error. The error is "Error (10372): VHDL error at vga_test.vhd(25): item cannot be assigned value". The error is at the red colour line. For your information, I used altera de2 115 for my project. Thanks for your attention.
library ieee;
use ieee.std_logic_1164.all;
entity vga_test is
port( clk, reset: in std_logic;
sw: in std_logic_vector(7 downto 0);
hsync, vsync: out std_logic;
red,green,blue: out std_logic_vector(7 downto 0));
end vga_test;
architecture arch of vga_test is
signal red_reg: std_logic_vector(7 downto 0);
signal green_reg: std_logic_vector(7 downto 0);
signal blue_reg: std_logic_vector(7 downto 0);
signal video_on: std_logic;
begin -- instantiate VGA sync circuit
vga_sync_unit: entity work.vga_sync
port map(clk=>clk, reset=>reset, hsync=>hsync,
vsync=>vsync, video_on=>video_on,
p_tick=>open, pixel_x=>open,
pixel_y=>open);
process(clk, reset) -- rgb buffer
begin
if (reset = '1') then
(red_reg and green_reg and blue_reg) <= (others => '0');
elsif (clk' event and clk = '1') then
(red_reg and green_reg and blue_reg) <= sw;
end if;
end process;
(red and green and blue) <= (red_reg and green_reg and blue_reg) when video_on = '1' else '0';
end arch;
    this is because "and" is a logical operation, not an aggregrate operation.
    If you really want to do it with an aggregrate operation, you need to write:
    (red_reg, green_reg, blue_reg) <= (others => '0');
    but whats wrong with 3 separate assignments?
    red_reg <= (others => '0');
    green_reg <= (others => '0');
    blue_reg <= (others => '0');
    Dear Tricky.
    Thanks for your reply. I already did the same as you mention. But there is another error. The error is "Error (10316): VHDL error at vga_test.vhd(35): character ''0'' used but not declared for type "std_logic_vector". Actually I refer this coding from website before I modify it for my project. Do you have any simple VHDL coding for VGA monitor. Thanks for your reply.
    library ieee;
    entity vga_test is
    end vga_test;
    pixel_y=>open);
    begin
    red_reg <= (others => '0') ;
    green_reg <= (others => '0') ;
    blue_reg <= (others => '0') ;
    red_reg <= sw;
    green_reg <= sw;
    blue_reg <= sw;
    end if;
    end process;
    red <= red_reg when video_on = '1' else '0';
    green <= green_reg when video_on = '1' else '0';
    blue <= blue_reg when video_on = '1' else '0';
    end arch;
    read/green/blue are std_logic_vectors, '0' is a single bit. You need to assign the entire array:
    either:
    x"00" = 8 bits, all zero
    (others => '0') set all bits to '0'
    for minima, if you kindly. may I ask the VHDL code that has managed this? I again learned to make VHDL code for VGA but do not understand its structure because I am still a beginner. beg the goodness of his heart.
    my name is wahyu, student from Indonesian.
    thank you so much :)
