11 years agoVGA using VHDL
Hi guys. I have problem with my VHDL code. I want to use VGA monitor for my project. Here is the coding for my testing. But, this have error. The error is "Error (10372): VHDL error at vga_test...
11 years agoDear Tricky.
Thanks for your reply. I already did the same as you mention. But there is another error. The error is "Error (10316): VHDL error at vga_test.vhd(35): character ''0'' used but not declared for type "std_logic_vector". Actually I refer this coding from website before I modify it for my project. Do you have any simple VHDL coding for VGA monitor. Thanks for your reply. library ieee; use ieee.std_logic_1164.all; entity vga_test is port( clk, reset: in std_logic; sw: in std_logic_vector(7 downto 0); hsync, vsync: out std_logic; red,green,blue: out std_logic_vector(7 downto 0)); end vga_test; architecture arch of vga_test is signal red_reg: std_logic_vector(7 downto 0); signal green_reg: std_logic_vector(7 downto 0); signal blue_reg: std_logic_vector(7 downto 0); signal video_on: std_logic; begin -- instantiate VGA sync circuit vga_sync_unit: entity work.vga_sync port map(clk=>clk, reset=>reset, hsync=>hsync, vsync=>vsync, video_on=>video_on, p_tick=>open, pixel_x=>open, pixel_y=>open); process(clk, reset) -- rgb buffer begin if (reset = '1') then red_reg <= (others => '0') ; green_reg <= (others => '0') ; blue_reg <= (others => '0') ; elsif (clk' event and clk = '1') then red_reg <= sw; green_reg <= sw; blue_reg <= sw; end if; end process; red <= red_reg when video_on = '1' else '0';green <= green_reg when video_on = '1' else '0';
blue <= blue_reg when video_on = '1' else '0'; end arch;
