11 years ago
VGA sync circuit
Can some one please tell me how this code increments the v_count_reg and h_count_reg?? because I just don't see it. Also what do they mean the output is buffered exactly? thanks in advanced
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
entity vgaController is
    Port ( clk : in  STD_LOGIC;
			  reset : in STD_LOGIC;
           hsync : out  STD_LOGIC;
           vsync : out  STD_LOGIC;
           video_on : out  STD_LOGIC;
           p_tick : out  STD_LOGIC;
           pixel_x : out  STD_LOGIC_VECTOR (9 downto 0);
           pixel_y : out  STD_LOGIC_VECTOR (9 downto 0));
end vgaController;
architecture Behavioral of vgaController is
-- VGA 640 -by - 480 sync  p a r a m e t e r s
constant HD: integer:=640; --horizontal display area
constant HF: integer:=16 ; --h. front porch
constant HB: integer:=48 ; --h. back porch
constant HR: integer:=96 ; --h. retrace "Sync Pulse"
constant VD: integer:=480; -- vertical display area
constant VF: integer:=10 ; -- v. front porch
constant VB: integer:=33 ; -- v. back porch
constant VR: integer:=2  ; -- v. retrace "sync pulse"
-- mod-2 counter
signal mod2_reg, mod2_next : std_logic;--mod-2 counter to generate the 25-MHz enable tick
-- sync counters,  two counters for the horizontal and vertical scans
signal v_count_reg, v_count_next : unsigned(9 downto 0);
signal h_count_reg, h_count_next : unsigned(9 downto 0);
--To remove
--potential glitches, output buffers are inserted for the hsync and vsync signals. This leads
--to a one-clock-cycle delay. add a similar buffer for the rgb signal in the pixel
--generation circuit to compensate for the delay.
-- output buffer
signal v_sync_reg, h_sync_reg: std_logic;
signal v_sync_next ,h_sync_next : std_logic;
--status signal
signal h_end , v_end , pixel_tick: std_logic;
begin
	--register
	process(clk,reset)
		begin
			if (reset='1') then
				mod2_reg     <='0';
				v_count_reg  <=(others=>'0');
				h_count_reg  <=(others=>'0');
				v_sync_reg   <='0';
				h_sync_reg   <='0';
			elsif(clk'event and clk='1')then
				mod2_reg     <=mod2_next;
				v_count_reg  <=v_count_next;
				h_count_reg  <=h_count_next;
				v_sync_reg   <=v_sync_next;
				h_sync_reg   <=h_sync_next;
			end if;
	end process;
	--mod-2 circuit to generate 25 MHz enable tick
	mod2_next <= not mod2_reg;
	-- 25 MHz pixel tick
	pixel_tick <= '1' when mod2_reg = '1' else '0';
	--status
	h_end <= --end of horizonal counter
		'1' when h_count_reg = (HD+HF+HB+HR-1) else --799
		'0';
	v_end <= --end of vertial counter
		'1' when v_count_reg = (VD+VF+VB+VR-1) else --524
		'0';
	-- mod-800 horizontal sync counter
	process(h_count_reg,h_end,pixel_tick)
		begin
			if (pixel_tick='1') then --25 MHz tick
				if h_end='1' then
					h_count_next <= (others=>'0');
				else
					h_count_next <= h_count_reg+1;
				end if;
			else
				h_count_next <= h_count_reg;
			end if;
	end process;
	-- mode-525 vertical sync counter
	process(v_count_reg,h_end,v_end,pixel_tick)
		begin
			if (pixel_tick='1' and h_end='1') then
				if (v_end='1') then
					v_count_next <= (others=>'0');
				else
					v_count_next <= v_count_reg+1;
				end if;
			else
				v_count_next <= v_count_reg;
			end if;
	end process;
	-- horizontal and vertial sync, buffered to avoid glitch
	h_sync_next <=
		'1' when (h_count_reg >= (HD+HF))  --656
			  and (h_count_reg <= (HD+HF+HR-1)) else --751
		'0';
	v_sync_next <=
		'1' when (v_count_reg >= (VD+VF))  --490
		     and (v_count_reg <= (VD+VF+VR-1)) else --491
		'0';
	--video on/off
	video_on <= '1' when (h_count_reg < HD) and (v_count_reg < VD) else '0';
	--output signals
	hsync <= h_sync_reg;
	vsync <= v_sync_reg;
	pixel_x <= std_logic_vector(h_count_reg);
	pixel_y <= std_logic_vector(v_count_reg);
	p_tick <= pixel_tick;
end Behavioral;
sorry for the rather stupid question.
    yes I'm testing on the board, it's not working.. but i think I figure out the problem and it has to do with syntax apparently.. thanks though, Not using Quartus for this one, guess thats the only thing this forum supports, I actually prefer Quartus over ISE
    If it compiled ok, then there are no syntax problems
    I highly suggest you write a testbench.
    --- Quote Start ---
    --- Quote End ---
    yeah that's right, I should have said logical errors. I don't get the point of writing a testbench, I mean first I have simulation tools, I can simulate and look at waveforms for example to confirm correct operation, secondly, I'm still relatively new to vhdl, I understand gate and transistor level circuits pretty well I would say, but VHDL I seem to struggle with, now if I'm trying to write a circuit and struggling how can I possible write another circuit to test the circuit I'm struggling with, thirdly, they never once suggest to us to even consider writing a testbench of any kind here, and I'm doing my last year, so it can't possibly be common practice, although this could be terribly wrong of course. That's a long sentence.
    Either way I manage to bang it out, I have pong on my vga!! lol thanks for your help guys I really appreciate it.
    Daniel
    Creating a testbench is always the first step after writing the code, before you even get to the FPGA, to test the operation of the design under test.
    For you testbench, you dont have to write synthesisable code, you can just write behavioural code. For example, here is how you would define a basic clock for a testbench
    signal clk : std_logic := '1';
    clk <= not clk after 5 ns; --100 MHz clock
    or maybe some hand crafted waveform:
    process
    begin
      input <= 1;
      for i in 1 to 10 loop
        wait until rising_edge(clk);
      end loop;
      input <= 2;
      wait for 1 ms;
      input <= 3;
      wait;
    end process;
