13 years agoVGA Calculator Display using VHDL
All right, so I'm trying to make a floating point calculator using VHDL, and basically, I want to first make the display. I want this calculator to display on a VGA monitor, and before I start ...
13 years agohello there
In order to display data on VGA screen you need a VGA Controller module (there is planty free example on the net) and you need another module to deliver data that you want to display (here function names) then anothor module is required to do the calculation Good luck
