13 years agovery strange Error(10500)...
I've tried to compile the following simple code (I've numbered the strings for this post, but not in VHDL file!):
1 library IEEE; 2 use IEEE.std_logic_1164.all; 3 use IEEE.numeric_std; -- (I've used .all, and without IEEE.numeric_std as well) 4 5 entity first is 6 port (A,B,C: in std_logic; F: out std_logic); 7 end first; 8 9 architecture my_first of first is 10 signal sig_1: std_logic; 11 variable var_1: integer; 12 begin 13 F<= NOT (A AND B AND C); 14 sig_1 <= A; 15 var_1:=38; 16 end my_first; This is just from the tutorial book. While compiling I get Error (10500): VHDL syntax error at first.vhd(15) near text ":="; expecting "(", or "'", or "." Please, point me my mistake, as I don't see any!
